wopachop's avatar
wopachop
Any tricks to storing a fresh water filter?
I bought a 2 pack of those basic blue colored water filters. The box says it lasts up to 3 months and store in the fridge.
Now what if i only filtered 100 gallons of regular quality tap water through it? Does it start to form mildew after 3 months? Or is the 3 months an estimate of gallons?
Guess i should probably email the manufacture. Instructions also say do not freeze.
What if i put 10 gallons through the filter every couple weeks to keep the water inside fresh? Maybe that could extend the life?
  • Oh that looks nice!!
    Do you ever put a very small amount of bleach into your fresh water?
  • I save the caps, drain after use, & recap it. Throw away after my camping season.
    I did not read the "store in fridge". I suspect that is to minimize any growth in it instead of leaving it in a hot RV iparked between uses.
    I will probably go the route Gdetrailer recommends next year.
  • Ditch the "one and done" filters, they are stupidly expensive for what you get.
    Instead get one of these..
    $35 at Home Depot.
    Then you can simply buy the replacement cartridges like these..
    For $9 for two filters..
    You will need to buy garden hose to 3/4 threaded pipe adapters.
    Once done, you will have a much better filter that will outperform any throwaway cartridge in flow and cost.
    When done camping, remove the filter cartridge and toss it, dry inside of filter housing and put away.
    Your life is certainly worth much more than the $5 per filter..
    Recycling throwaway filters is not worth taking a chance with your health..
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
