StirCrazy
Feb 23, 2025Moderator
get a quick connect hose and attach it to a large BBQ (just find a BBQ that has a separate reducer and regulator) you unscrew the reducer from the regulator then use the rv's system to supply low pressure and it will work good. I use a Webber q for camping and it is perfectly set up for this if you want a small BBQ to take with you after.
