naturist
Dec 01, 2020Nomad II
May I suggest going to the mobile-solarpower.com web site? Will Prowse has developed a LOT of expertise in the solar power field.
I'm not running lithium batteries, but I am fairly certain that your 360 watt array is not adequate for the task. That certainly won't get you 200 AH of power reliably. This is pretty much certain given your max voltage of 12.6 volts on your existing battery pack.
I am running with a pair of 125 AH AGM batteries, and they aren't fully charged until up to 13.0 volts. But this depends on how you are measuring that voltage. Is it via a VOM when they are disconnected from any load? Or is it by use of a battery monitor of some sort? If the latter, does your system contain a shunt? Or is it just the display from that MPPT controller?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
