dougrainer
Feb 14, 2016Nomad
If just the motor, you remove 1 or 2 (depends on the LCI style) 9/16 bolts that hold the motor and the motor just pulls loose. IF you purchased the complete telescoping assbly you remove the 2 bolts that hole the motor end and remove the 3 large nuts on the end threaded and pull it out. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
