John_Joey's avatar
John_Joey
Anyone have a Carrier AC remote that runs the furnace?
New to me rig and I can't make the furnace kick on. It has a remote for the Carrier AC that also runs the Atwood furnace. When I put it into heat mode, I hear nothing, and that is exactly what I get :S
First time I had this type of a setup, and I'm running into problems finding info on the net. Any ideas from those that have/had this type of setup what I might need to do to get it work?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have that system. I also have two A/Cs. only the FRONT one will make the furnace furn. (Is that a word).
    Also there is a switch on the furnace itself (outside behind the access panel) this switch does double duty as a circuit breaker.. There is also a fuse in the usual place (Fuse box).
    Now you might (or not) hear a relay click likely a few seconds after you select HEAT mode with a temp setting at least 5 degrees above what it is, or more. The Temp sensor for this unit is not (As many think) the remote, it is part of the A/C grill (little yellow tit) so it's warmer up there than it is around your toes. I've had to put a fan on the dang thing to settle it down and make it behave on occasion.
    Next: To see if it will work at all:
    Press and hold the Furnace button till you hear a BEEP (2nd beep) This will take several seconds. The furnace should come on almost immed.
    If that does not work remove the ceiling cover (intake grill, 4 screws, two are hidden by the filter) and look for some BLUE wires coming out of the control box.. If they are not connected, Then that's not what controls the furnace.
  • The next thing you will find out is if you set it at 70 degrees the furnace will shut off when it reaches that temperature. But it will only be 70 degrees up at the ceiling where the thermostat is. Set it a few degrees warmer than you want it so you get the proper temp down at living level.
  • So... here's some more info. Does your remote have a FURN mode as well as HEAT? If so, you'll find the FURN mode operates only the propane furnace and the HEAT mode operates the heat pump(s) until it gets too cold for it/them and then it kicks to the furnace automatically.
  • SIDEBAR NOTE:
    I posted at 9:26 and got heat at 9:38, you just got to love the internet, and those that care enough to help.
    Really appreciate it!!!
  • msmith1.wa wrote:
    I used to have one. You need to aim the remote at the ac when making changes to the settings. There should be a beep from the ac to indicate that the change has been received.
    BINGO, we got a winner!!!! I owe you a cold beverage :B
    THANK YOU!!!
  • I used to have one. You need to aim the remote at the ac when making changes to the settings. There should be a beep from the ac to indicate that the change has been received.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
