Hank85713
Jul 01, 2015Explorer
Most require the lines to be cut SQUARE so that he airline fits all the way in to the valve. You might have some that do not fit securely. If they are the plastic valves that could be one problem. Go to a NAPA or Car quest and see if you can get the BRASS connectors as used on big rigs. If not then go to hardware store and buy the brass connectors for 1/4 inch lines.
Another possibility is that one of the lines has a break in it someplace along the frame. I had my lines contact a tailpipe and I thought I blew a airbag? got replacement bags and then found the broken airline.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
