- linthibExplorerThank you!
It was the dump valve that was the problem.
Actually the filter that allows the air intake was clogged---now I just have to find out where to get those and order a bunch.
:D - sdianel_-acct_cExplorerDo you have automatic leveling? HWH?
- Hank85713ExplorerMost require the lines to be cut SQUARE so that he airline fits all the way in to the valve. You might have some that do not fit securely. If they are the plastic valves that could be one problem. Go to a NAPA or Car quest and see if you can get the BRASS connectors as used on big rigs. If not then go to hardware store and buy the brass connectors for 1/4 inch lines.
Another possibility is that one of the lines has a break in it someplace along the frame. I had my lines contact a tailpipe and I thought I blew a airbag? got replacement bags and then found the broken airline. - answerswillvaryExplorerMoved from Roads and Routes to Tech Issues
- midnightsadieExplorer IIget the soap and spray all connections , fix as you go, I,m a older guy and its great to have a grandson who llikes to help out.
- linthibExploreris there any way these valve could be sticking or gummed up?
If so how do I fix?
Appreciate the suggestions and letting me vent... - linthibExplorerthank you!
I am having problems locating parts---Jayco says not their valve that is leaking.
Difficult if not impossible to find anyone who knows anything about RVs here in NH.
Also why isn't there a manual for all the stuff---like fuses etc?
Never mind the electronics. And everytime someone fixes something, something else is no longer working!
We are supposed to be on the road for an extended vacation---at this rate we won't be leaving the driveway! - RbertalottoExplorerYup, little leaks everywhere on my after market air bags. I keep tracking them down and fixing usually at the push-on type connectors. Some day I'll replace all those connections with another more secure type. With an on-board compressor its not a big deal. I lose about ten pounds of pressure over a three hour period.
- sdianel_-acct_cExplorerIf you have automatic leveling (HWH) have them check the dump valve in the rear. Ours was leaking.
- 2oldmanExplorer IIIf you have an onboard compressor and tank, check the tank for leakage from the water vapor vent.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
