sdetweil's avatar
sdetweil
anyone install Onan genset in front compartment?
I am getting close to finishing my genset install project.
Found a not working 7kw onan genset, repaired the broken drive pulley and replaced belt.. converted to propane, runs great. have added the Transfer switch to the FW and wired to the front compartment. Had the metal enclosure built and have the floor cutout template..
now to actually put the genset into the front compartment.. but the thing weighs 300lbs. I can't find any specs on what the floor of the front compartment will hold. (keystone tech support didn't have any specs for the floor weight capacity)
also, the floor is 3.5 inches lower than the door opening, so once you get it in there, I don't know how you would ever get it out. (the enclosure is big enough that you couldn't get it out first.
so I've been looking at creating a drawer, or at least mounting the genset on risers to get the base even with the front door opening.
this only makes the weight thing more of an issue, cause all 300lbs will be sitting on the base of the riser (in either case).
lets do the weight math,
risers are 3.5in square tube, 24 inches long, and need 2 of them.
300lbs/(24x3.5x2)
that comes out to 1.75 psi. not much
the floor seems to be some thickness sheet metal (haven't cut it yet), resting on the legs of angle iron, which are welded to the frame (I think)
if I can get the riser to rest on the (1"?) angle iron lip too, then the pressure on those two would be
300lbs/(1x3.5x4) = 21 psi each end of both risers. (300/4/ 3.5sq in)
I have some 3/16 x 7 x 36 strips of flat stock that I could use as reinforcement in the riser area. not enough for the whole floor section as 1 piece.
here is a side view of the layout
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
