- timjcarter9ExplorerThanks. Got it fixed now that I know where it was supposed to go.
- full-timerExplorerThat appears to be a Dometic frig. That is the Thermistor,it fits in a clip and clips on the cooling fin to adjust the temperature of the frig.
Joe - timjcarter9Explorer
neschultz wrote:
I think it is your thermostat sensor. My snaps into the white plastic bracket on the right side of the fins that slides up and down to regulate the temperature.
Thanks
That makes sense. - neschultzExplorerI think it is your thermostat sensor. My snaps into the white plastic bracket on the right side of the fins that slides up and down to regulate the temperature.
- timjcarter9ExplorerNope. Drain is on the left under the tray. Drains into a little built in funnel like outcropping then out the drain hose on the outside.
See here.
This thing has a solid end. - LearjetExploreris that your drain line that should be connected to your drip tray?
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 08, 2026
