footslogger
May 30, 2013Explorer
lj2654 wrote:
should not need any for your aquahot on a 2012 coach, unless you have a leak.
Even though this is a nominally closed system, there can be some evaporation, particularly from the over-flow tank, which is not sealed. It is not unusual to add a quart or two a year, even if there are no leaks. Coolant loss can vary with the hours that the system is heated. With a lot of winter use, or if your system is heated with the engine, evaporation will be greater.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
