msmd1's avatar
msmd1
Aqua Magic IV cleaning
I have noticed that there is a cavity underneath the slide valve to flush the toilet that collects a considerable amount of fecal matter. There is mold and mildew and smell! Any suggestions on cleaning products and perhaps a better toilet solution that does not have this inaccessible cavity? I removed the toilet to replace the flush valve (after it spewed water everywhere for a few minutes) and found the source of the smell. Thank you in advance.
  • wyocowboy00 wrote:
    I think you can add an optional hand sprayer to that toilet. Give Thetford a call.
    Not an option on OPs Aqua Magic IV and wouldn't be a good idea with the 'open cavity' issue of that toilet design
  • I think you can add an optional hand sprayer to that toilet. Give Thetford a call.
  • Check out the Thetford Aqua Magic Residence, Style II and Style Plus
    Also the Dometic 320
    The optional Hand Sprayer is great for rinsing down-tube (vs that open cavity)
    Using your preferred version of tank wand to help clear the tank of "debris" will also clear the toilet throat.
