Jetjock15
Mar 03, 2019Explorer
enblethen wrote:
The lights and fan are 12 volts DC. Locate your 12 volt power distribution panel. It is commonly adjacent to the 120 volt AC circuit breakers. Odds are that there is blown fuse.
120 volt receptacles are only hot when plugged into shore power whether it is power from pedestal or genset. It could have a tripped circuit breaker in the 120 volt panel. Turn off all circuit breakers, applying light pressure toward off then turn them back on one at a time. Make sure you have 120 volts AC to rig.
I did try reseting all circuit breakers as I read that in my google searches. Also checked all fuses in the fuse panel. I have the same issue when I tried shore power at campground, home, and inboard generator. It just the couple lights in bedroom, the fan, and two outlet plugs, none have power
