valhalla360
Jan 04, 2021Navigator
Second Chance wrote:lamopar wrote:
Thanks. That lines up with what I thought. I see the propane pipe is below the plastic sheet so this will be a good challenge. I think I will replace these valves with electric units once I can get access to them. We camp at the ski resort in freezing weather so I need the valve to shut every time.
Replacing the manual valve with an electric one won't make it any more reliable - probably even less so (more parts and a motor to fail).
Rob
Agreed, you add complexity and more parts that can fail.
I would look at an easily removable panel if you are worried about it failing again. If you can get at it, it's really not a big job to pull it apart and either clean up or replace the valve. Your bigger issue is if you can't get it open because now you have a full tank and when you go to pull it apart all that waste is going to come gushing out.
They are fairly reliable if you use them regularly. Don't leave the valve in the open position except when dumping. Otherwise, crud can get into the slots the valve fits into and cause it not to seal properly.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
