mena661
Aug 28, 2013Explorer
12thgenusa wrote:I believe he does the finish charge like I do. At least a few days after my converter goes into float (typically I wait till the next weekend), I hook up either the manual charger (quicker) or if I don't have time to babysit I use the B&D1093. With the manual, I just let it run till SG stops rising (2-3 hrs) then wait a few hours or the next day when I have time and check the final SG. It's always up at baseline (1.285). With the B&D, I run a charge session then when it's "full", I run an equalize session (it won't let you do the EQ without a charge). When it's done, I check SG. If it's not up to baseline I do another. I have found it takes two EQ's with the B&D so now I just do another. The B&D takes a lot longer but I don't have to babysit it as much. I keep a spreadsheet of the volts, air temp, batteries temp and SG readings.
So I guess you blindly blast away for some arbitrary length of time at some arbitrary time interval and then assume the batteries are full?
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
