ktmrfs
May 23, 2019Explorer III
are they the same? mostly.
Can you use a home microwave to replace the RV microwave? yes. need to check dimensions but yes, there are many to choose from. many have mounting holes on the bottom and are the same or close enough dimensions to be a replacement fit.
I tossed the microwave in our RV and replaced it with a panasonic true inverter microwave. Advantages A better microwave, and when in other than 100% power it doesn't cycle power between 0% and 100% it actually drops magnetron power. So (1) generator doesn't hunt up and down, (2) If I set it to 50% power I can run it off my 1000VA inverter. And at 50% it doesn't take twice as long to heat/cook something, more like 25% longer. And it has a better defrost cycle and better popcorn cycle than the original microwave.
And the panasonic mounting holes lined up with the OEM holes and the OEM surround trim fit perfect on the panasonic. Even vented the same.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
