Boon_Docker
Jan 19, 2023Explorer III
Fisherguy wrote:waexplorer wrote:
If your charging amps are above 40 amps I'd say that's ok. Most lithium batteries have BMS's that are 50 amp or 100 amp charge/discharge capable. 55 watts is the max system output including lights, accessories etc. Whatever is left is for charging. If you're not having issues I wouldn't change it yet. You want charge voltage around 14.4 for lithium. If it's 13.6 or so that is for flooded lead acid. Lithium batteries don't have float mode. There are several good youtube videos show lithium charge and discharge curves. Do you have the Zamp 30 amp solar controller above the bed like mine? Make sure it is set to lithium also.
The previous owner told me he changed the charger for one that's compatible with Lithiums and when I slid the charger out I saw "8955Lis200724" on the label and assumed the 'Lis' part of it meant it was the Lithium charger but after doing some more clicking I now don't think it is. It doesn't look like the one on the WFCO site that sposed to be the Lithium conversion:
lithium replacement
I want to get the most bang for my buck when I need to fire up the Honda 2000 to charge the batteries so I'll be looking for something that puts out 75 or 80 amps or something.
According to the WFCO website, your "8955Lis200724" is lithium compatible.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
