Fisherguy
Jan 25, 2023Explorer
theoldwizard1 wrote:
Buy a GOOD quality inverter/charger/automatic transfer switch. Remove the converter and wire the DC fuse panel directly to the house battery bank (using a large fuse close the the battery bank).
Wire the shore power cable directly to the inlet of the inverter. Wire the outlet of the inverter to your AC breaker panel.
DONE !
Ya I'm looking into them. We only have a 600 watt inverter in our old trailer for TV sat dish etc and it's worked well. It seems the "all in ones" have 2000 watts as a minimum on the inverter side and only have about 1 amp no-load draw so that's not too bad.
Can you adjust the charging rate of the Victrons? Last thing I'd want is to put one in that was more than our Honda 2000 genny can power.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
