swimmer_spe
Jul 01, 2021Explorer
Gdetrailer wrote:
No such thing exists and if it did would be more expensive than your RV.
The closest thing to armored cable that I can think of is this
"BX" cable, but, it is not designed for and cannot be used for outdoor use, it is not designed to be run over..
Find a different route such as overhead or take it the long way around or bury conduit under the driveway and run some wire through the conduit and terminate to a RV outlet.
You could also try cord protectors that look like this..
That one is rated for 22,000 lbs but it is expensive for a 40" length..
Found HERE for $52.00
Those covers might be a better way to go.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
