fj12ryder
Jul 02, 2021Explorer III
afidel wrote:What exactly would be the issue? Just curious, as I know it may not be up to code, but there is PVC conduit, so why would a bit of PVC pipe run under a driveway be an actual problem.
Don't run an extension cord through conduit, it's not rated for that. Get an electrician to run proper rated cable through conduit and setup an outlet in an outdoor rated enclosure to plugin. If you do the trenching and conduit install it won't even be that terribly expensive.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
