Dusty_R
Jul 04, 2021Explorer
wopachop wrote:
Oh perfect!! You already have wire run in conduit over there. You should be able to get a standard 15a receptacle on that.
Depending on conduit size he might be able to pull thicker wire and give you a 30a setup. If you ever wanted to run heaters and stuff come winter 30a would be awesome.
If you post a picture of your service panel people here might be able to give advice on what to do. It could be really easy to put that outside junction box on its own 15 or 20a breaker. So its not sharing power with the house. I had to do that back home. We plug the trailer into the garage outlets. But it kept tripping the breaker. So i gave 1 outlet its own dedicated 20a breaker. The breaker was already there. Just had to swap wires around.
Ideally that outside junction box is already on its own circuit. Like you said it will be cheap to add an outlet right there.
Have you pulled the cover and taken a peek? Hopefully its not low voltage wire for outdoor lighting. If it looks like speaker wire then he will have to pull new wire.
When you switched wires around. I hope that you didn't put #14 wires on a 20 amp breaker.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
