dougrainer
Jan 27, 2017Nomad
This is the reason to install the ARP. It does NOT improve the actual cooling as long as all parameters are to spec. The main thing it does is STOP the cooling process when you park off level for those short periods of time that can start a cooling unit break down in a few years. Doug
Your RV Refrigerator boiler operates at about 350 degrees all the time, but even a brief time off-level, like driving up a hill , can send that temperature sky-rocketing. Events like this produced a lot of thermal stress in the fridge boiler, stress that causes the metal to fatigue and the anti-corrosion chemicals in the coolant to deteriorate leading to fridge failure and perhaps even causing an RV fire. This is the reason for Dometic and Norcold recalls leading to class action suits. The ARP Control can monitor the boiler temperature and automatically shut down the boiler if temperatures begin to climb out of normal range. Best of all, ARP continues to monitor and re-starts the fridge once it cools down again, so that your food doesn't spoil. And all without any effort by you!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
