- wolfe10ExplorerPirate,
Contact Paul and ask him-- certainly the best source of information on the product he designed and produces.
https://www.arprv.com/ - Pirate1Explorer
LarryJM wrote:
I knew there would be at least one person who told me I didn't know what I was doing. When I installed mine years ago, it clearly provided instructions for including your visual and/or audio sensors. I did it. Otherwise, how do you know it is working. I'm saying mine has never done anything. Larry, my install is done the right way.Pirate wrote:
wolfe10 wrote:
Funny, I installed mine carefully, tested it, followed all directions yet I have NEVER had an alarm for overheat, regardless of angle, etc.
No need to sense level, as running out of level for even a short time will dramatically raise boiler temperatures. And the temperature is much easier to measure than angle, as with angle you also have to account for acceleration, deceleration, bumps, etc.
At the Seminar Paul gave at an FMCA Convention, he had a test cooling unit set up with his control unit installed on it.
Up on the screen was a temperature monitor he had set up with probe on the refrigerator boiler. He raised one end of the test cooling unit on a 2X4 (so less than 2"). While he talked (less than 5 minutes) we all watched the screen and could see the temperature rising VERY quickly up to the point where the controller turned it off. Then once it cooled down, the controller re-started the cooling unit.
It appears you either didn't either read or understand how the ARP system works. There are NO ALARMS or any indication that the system has been activated unless you go thru the system menu and pull up that information manually. It simply does what it's designed to do "PROTECT the COOLING SYSTEM" silently and basically in the background. I think, but might be wrong if there are multiple shutdowns over a certain period of time then the system will shut down the unit and it will not come back on automatically until it's reset, but I would have to go back and double check that to see if that's actually true. I just always have my remote unit displaying the boiler temp and that way I know when the cooling unit is actually activated.
Larry - pianotunaNomad IIIPirate,
It will reset the fridge 4 times. On the 5th overheat it shuts the fridge down. - LarryJMExplorer II
Larry - Harvey51ExplorerIt makes sense to just measure temperature, which has the dangerous and damaging effects. I don't much like it turning back on while still unlevel, though.
- wolfe10ExplorerI know nothing about an alarm. At least on the test unit, it QUIETLY turned off the cooling unit and then turned it back on.
Guess it could be wired to trigger an alarm, but not sure of the advantage.
Automatic is what most want, not an alarm.
Does yours turn the cooling unit (heat source) off if boiler temperature rises? - Pirate1Explorer
Up on the screen was a temperature monitor he had set up with probe on the refrigerator boiler. He raised one end of the test cooling unit on a 2X4 (so less than 2"). While he talked (less than 5 minutes) we all watched the screen and could see the temperature rising VERY quickly up to the point where the controller turned it off. Then once it cooled down, the controller re-started the cooling unit. - Chris_BryantExplorer IILevel doesn't matter- circulation does. The discontinued Atwood had a level sensor- didn't help.
- wolfe10ExplorerNo need to sense level, as running out of level for even a short time will dramatically raise boiler temperatures. And the temperature is much easier to measure than angle, as with angle you also have to account for acceleration, deceleration, bumps, etc.
Up on the screen was a temperature monitor he had set up with probe on the refrigerator boiler. He raised one end of the test cooling unit on a 2X4 (so less than 2"). While he talked (less than 5 minutes) we all watched the screen and could see the temperature rising VERY quickly up to the point where the controller turned it off. Then once it cooled down, the controller re-started the cooling unit. - Harvey51ExplorerSounds like it has only one sensor (temperature). So all it knows is the temperature.
There is no mention of a level sensor in the docs. A couple of mercury switches would be the basis of an unlevel alarm, no electronics needed. I'm sure the manufacturers could add that feature without infringing any patents. Why have they not done so? My cynical side wonders if they sell more fridges without the safety devices.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
