DrewE
Nov 02, 2020Explorer III
If it's just the furnace, any normal (residential) digital thermostat that has its own battery for power will work just fine. Select one with the features you want. Relocating the thermostat itself means rerouting the control wires, or running new ones, or extensions, or something along those lines.
If the same thermostat also controls an air conditioner, it may or may not be compatible with standard thermostats; that depends on the model of air conditioner and whether it has some proprietary (usually digital) thermostat interface.
