wilanddij
Apr 08, 2016Explorer
Disconnect the batts when the RV is covered. House batts will totally disconnect using the switch. Chassis battery needs to be physically disconnected to avoid rundown by parasitic draws. Most physical battery disconnets can be easily installed into the ground side of the battery.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
