jschultzuw
Nov 27, 2015Explorer
You got it. I called someone local this morning and they had the same response. Switched them and it worked. I took the leads off, got the battery, came back and hooked the black to negative (like anything else I've wired) and didn't think twice. I should have... :)
Thank you for your response.
I still have the issue of the KIB Montior board not working. I'm guessing it got fried. Do you know if the new boards will accept the same pin harness that is coming out of the wall?
Thanks!
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
