Edd505
Jan 03, 2020Explorer
Old-Biscuit wrote:
Clean tank wall before installing new t-stats?
T-stats TIGHT against tank wall or temp to open will be higher
Can't reverse the ECO and t-stat----use different size spade connectors/terminals
Have you let it run until t-stat OPENS or ECO Opens?
Electric....
No DC on YELLOW Wire
Relay bad
AC wires on Relay bad
Bad element
Bad ground wire connection
Follow the DC....then the AC
Resident expert, follow his advise and you will fix it. (Thanks again, working purfect)
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
