J_Walker
May 23, 2013Explorer
amxpress wrote:
According to Atwood, it is suppose to open at 140 Degrees.
Maybe the question should be, why is it getting so hot?
The Atwood water heaters work at a high thermostat setting, non adjustable. I haven't measured my water temp but it must be close to 140 degrees. The pressure relief valve works on pressure generated by the expanding water.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
