dougrainer
Jul 29, 2023Nomad
WHERE did you get the PCB board. 4 or 5 years ago, Atwood/Dometic had thousands of brand new defective PCB boards and replaced those under warranty. At the time I wondered what would happen to ALL those recalled boards. Even Boards that were stocked by suppliers were recalled. I believe some bad actors got hold of those bad boards and now are selling them. There is NO identification to tell which were bad and which were good and the year model of them. But based on your LACK of 12 volts for a few seconds at the gas valve, that points to a defective PCB boards. Ignitor lack of spark or NO spark will not affect the 12 volts to the gas valve. It will stay on until the 15 second ignition cycle ends, and then the PCB will kill power to the Valve. Send it back to your company you purchased from and get a replacement. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
