enblethen
Jul 29, 2023Nomad
You do not have to remove gas valve to check coils. hardest thing is ground is connected to valve mounting bracket on back side.
There should be two wires coming off valve that goes to ground. Two wires go to the thermal cut out connected to it with a 1/4 inch quick connect. Easiest way is to cut that connector off and test coils.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
