dougrainer
Jul 30, 2023Nomad
When it works 10 times out of 12, checking the coils is futile. AS I stated, the Ignitor/Gap/sparking(OR BAD) HAS NOTHING TO DO WITH 12 VOLT POWER TO THE GAS VALVE and keeping the gas valve open. IF you have a failure of Spark system, the gas valve(if operational) will continue to spew LP until the Ignition cycle is done(about 15 seconds). THAT is why the manual states to wait a minute or so between ignition cycles to allow any accumulated LP to disperse. IF you have a lapse of 12 volt power to the gas valve, then the problem IS the PCB board. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
