gillman's avatar
gillman
Atwood 6 gallon Water Heater - Not working on Electric..
Need some advice. I am new to Atwood Water Heaters (gas/electric model - GC6AA-10E). I have had 3 other RVs but they all had suburban water heaters and the most recent one was gas only (for 10 years...)
The Water heater works fine on gas. I think the electric heating element might have gotten smoked but not 100% sure. What other things do I need to check before I get to that? From the research I have done on this site and others, I don't find too much on the electric side. Almost everyone asks questions on the gas portion.
Historically, if it is going to be weeks between use, I drain the WH. I think someone turned on the WH by accident (maybe me) when we were setting up. The WH electric switch is just above my light switch in the panel.
I always drained the Suburban WH to keep the anode rod from eating away and to keep the smell away. Worked for years but it was gas only and I didn't worry about an electric element... I might not continue to drain it so often once I get it fixed.
Anyway: 2 questions: 1) what other things do I check before concluding it is the element (and how do I know that for sure?) and 2) how the heck do you change it if I need to? Is it really on the backside of the tank?
Thank you in advance for your advice!
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
