Loganhorse
Jan 03, 2021Explorer
Old-Biscuit wrote:
DC+ from a fused source goes to circuit board 'PWR' connection
*also the source of the DC+ to thermostat
When thermostat closes that DC+ comes back and goes to circuit board multi-pin connector
*also goes to Sail Switch
When circuit board gets that DC+ from the thermostat it sends DC+ to Fan Motor from the 'BLO' connection on circuit board
Got DC+ to 'PWR' on Red Wire
Get DC+ on Blue Wire at the multi-pin connection
No DC+ on Red Wire from 'BLO' to Motor
*Could be Circuit Board
*Could also be Sail Switch stuck Closed...Circuit board will not allow fan operation if Sail Switch is Closed BEFORE Fan runs
***Link Removed***
I will chech the sail switch when I get home from work. If the circuit board is bad, can one replace the relay on it instead of the whole board since I figure that's what is bad?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
