dougrainer
Feb 29, 2016Nomad
Have you checked the Hi limit switch? That is the switch that continues the fan running when the burner shuts off. IF that Limit is weak, it may open and then close. When it closes it will start a new cycle, which should NOT happen as long as the tstat is not calling for heat. WHY this continued operation would kick the CB, is unusual. Usually the only thing that will kick a CB is a defective fan motor. A Direct short would happen all the time. I would replace the motor. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
