Chris_Bryant
Feb 29, 2016Explorer II
OregonTravelers wrote:Chris Bryant wrote:
Check the current draw of the motor, then replace the breaker. Original was often a 7 amp, replacement is a 10 amp.
Don't guess that is the problem. The main furnace, the one with the problem has a 15 amp circuit breaker and the second furnace in the bedroom as a 10 amp breaker. Any other suggestions?
Carl
The breaker is tripping. There is nothing in a furnace short cycling which will cause an increase in current draw- it is not like an air conditioner, thus, something is wrong with either the blower motor or breaker.
The only other problem could be a short, which should be pretty obvious, as it would be right there in the furnace.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
