OregonTravelers
Feb 29, 2016Explorer
One thing I forgot to mention. The problem with the furnace cycling one and off and then tripping the 12 volt circuit breaker happens more when the thermostat is set at 65 degrees or more. It used to not happen below 65 or above 70 degrees. But now the problem occurs at all temperatures about 60 degrees.
That is why I was thinking at perhaps the problem was in the thermostat.
Carl
Carl
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
