dougrainer
Mar 01, 2016Nomad
liborko wrote:
Did you check burner? You have to remove valve assembly to do that. Four screws. And replace a firing electrode while it is easy.
I suspect the burner grid is rusted/gone allowing to burn too much gas triggering the limit switch. The motor starting current is very high and repeated starting might overheat the breaker.
Atwood part number for burner:#30268
Atwood part number for firing electrode:#34570
Good luck
He has BYPASSED the limit switch and it still malfunctions. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
