Chris_Bryant
Mar 02, 2016Explorer II
Y'all can talk about the thermostat as much as you want, but I could replace it with a Morse code key and key the unabridged Oxford English Dictionary and not trip that breaker. This furnace is not an air conditioner. Short cycling cannot and will not cause excessive current draw- certainly not (at 15 amps) nearly double the rated draw (8 amps).
When you have a system that does not work, and you know there is a fault, you fix that fault before anything else. Now I wouldn't do anything before actually measuring the current draw of the motor, but there really is not that much more that it could be.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
