OregonTravelers
Mar 09, 2016Explorer
trailrider wrote:
REPLACE THE MOTOR!!!
Most likely all of your furnace problems will disappear
OK, that is the next step. But I still don't understand how a weak or bad blower motor will cause the furnace to complete the heat cycle, turn off and then immediately start a second cycle including clearing the furnace, ignition, heat, heat off, and finally the fan stopping. Then almost immediately starting the sequence again. Doing this three or four times and then finally tripping the 12 volt circuit breaker.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
