liborko
Mar 09, 2016Explorer
You may have a defective motor but that does not cause cycling. The thermostat can not control furnace that does not work properly.
If your burner does not work properly the firing/flame sensing electrode will not keep flame going. So I suggest again remove valve assembly and check condition of burner and firing electrode. Replace the electrode with the style that has wire coming out instead of plug-in terminal that has a tendency to corrode & make poor connection. You already have Atwood part number.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
