OregonTravelers
Mar 18, 2016Explorer
Chris Bryant wrote:
At the risk of....
There are many ways a bad motor can cause cycling- in addition to what Doug pointed out, a 15 amp draw will pull the voltage down, and can easily pull it down far enough that the time delay relay will disengage, as well as the electronics dropping out.
We know that the motor has problems- a quick check of the current draw would verify that. Why throw parts at a furnace before you fix the main problem?
OK Chris. The dead horse has been whipped. Finally had the blower motor checked. The motor draws 7 amps. Exactly what it is rated to draw. Furnace still cycling on and off.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
