bigfootford
Jan 10, 2016Nomad III
fischer wrote:
the board has a time delay for turning the gas valve on/off.Also the fan delay for turning the fan off. Here is the link for troubleshooting you furnace. The first thing a all techs do is check all connections on the board also battery should be fully charged. http://bryantrv.com/docs.html
Good suggestions, I will expand a bit:
Sounds like the OP battery (s) are low or your converter/charger is not functioning.
Fan slows = low battery! Fan may continue to blow because the controller does not have enough voltage to control the furnaces functions.
Make sure that you are plugged into shore power, check your battery monitor if you have one.
Plugged in after about 30 min your battery monitor should show that the battery voltage is high.
This is not a charged indication as some believe... It takes hours to charge a low battery!
Here is a direct link to the furnace section of the manuals provided by Bryants.
http://bryantrv.com/docs.html#furnace
Jim
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
