Old-Biscuit
Jan 10, 2016Explorer III
TomTHaullie wrote:
Thank you for all the responses so far!
Been connected to shore power since October. No issues anywhere in rig with the 12v system. When fan straight wired to battery, runs at speed. Board and fan getting 12.39v to them. There is a discoloration at the motor connector on the board .... probably from short.
New info .... when cabin comes to temp, flame shuts off, fan slows, and LED flashing/clicking atarts. I waited 5 minutes with mo change. When I bump thermostat to higher temp, fan speds ip and flame does not come on. Clicking stops. Blows cold air until I turn off system at thermostat or outside switch. Reset outside, and it will cycle and flame/heat once. Repeat.
All I am reading suggests that there is a board control issue with fan control or flame sensing or something around that part of cycle. I will take board to dealer tomorrow and have tested.
Like I stated earlier.......blower power on board
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
