TomTHaullie's avatar
TomTHaullie
Atwood 8940-III fan won't stop
Can someone offer guidance with my furnace? Atwood 8940-III had burned out/seized motor. Tech replaced motor, sail switch and on/off 15a switch on unit. Now it runs, cycles on and heats great. When it comes to temp, flame cuts off but fan only slows a lot .... and board LED flashes pretty much constantly until I hit the off switch on the unit outside.
I am guessing a relay, bad board, or maybe limit switch since that switch not replaced? Relay appears part of the board these days.
Gotta hit road in two days, tues AM, so may not be able to get tech back out. Need assist in case of DIY on this part now that heavy lifting was done. Thanks for any guidance I can get.
Having RV issues? Connect with others who have been in your shoes.24,291 PostsLatest Activity: Jul 30, 2025
