CT_WANDERER
Feb 18, 2014Explorer
Atwood electronic Water Heater Board
At our park, a camper water heater failed. He called a mobile RV Repair Service. They replace his control board with a Dinosaur Board. It is working, however, I noticed if you turn off the main control switch inside the RV, then turn it back on the LED fault light right under the switch will come on for about 3-5 seconds. Then the LED goes out and the unit fires off. Other that that it seem to be working OK. Is this normal with the Dinosaur Boards?
I know with my stock board the fault light only come on if it faults out after three tries? Just wondering. Anyone know about the new board? Thanks Gary
