pnichols
Dec 21, 2018Explorer II
azrving wrote:
A good air powered pencil type engraver is very hand for vibrating things loose. Sometimes you can soak a broken bolt and use a center punch to put a spot on it near the edge. You then use the engraver to work it back and forth. If the blower wheel could be reached it might help loosen it. It's like micro beating it and breaks the bond.
Great tip .... thanks!
I wonder if there are now available battery powered pencil type engravers - so that I don't have to break out the compressor I carry in the RV and start up the Onan to power it?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
