dougrainer
Oct 12, 2018Nomad
1. There is NO air/mixture adjustment
2. You state black soot. That means you have a inlet fresh air restriction which is usually a Mud dauber nest or insect nests. Don't care if you state new, the insects can get inside on day 1 or on the Dealers lot.
3. The furnace will have to be pulled to verify the problem. IF insect nests, NO WARRANTY from the OEM or Atwood. If this happened at the dealer, then you would have to go back thru him. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
