pnichols
Oct 12, 2018Explorer II
dougrainer wrote:
1. There is NO air/mixture adjustment
2. You state black soot. That means you have a inlet fresh air restriction which is usually a Mud dauber nest or insect nests. Don't care if you state new, the insects can get inside on day 1 or on the Dealers lot.
3. The furnace will have to be pulled to verify the problem. IF insect nests, NO WARRANTY from the OEM or Atwood. If this happened at the dealer, then you would have to go back thru him. Doug
Hmmm ... can't the OP just take the outside furnace cover off and run something flexible back and forth in the burner tube to clean out any insect stuff?
I've looked at my Atwood furnace and it seems easy enough to do. I actually did this to my hot water heater burn tube to clean it out after black smoke dirted up the outside of our RV above the hot water heater burner vent outlet. It was easy to do.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
