time2roll
Jan 29, 2016Nomad
Casinojunkie wrote:Yes sounds like your furnace is improperly cycling against the high limit switch due to inadequate air flow.
The burner burned about 3-5 minutes then shut off for about 3-5 min. did this several times.
Switch probably gave up from over use.
See page 27 for minimum air flow requirements.
