brulaz
Jan 30, 2016Explorer
Had similar issue and it was a faulty regulator at the tanks.
It could release enough gas for the range and water heater, but the 35K BTU furnace's demands brought it to its knees. The furnace would click and sputter and then turn off. The problem appeared over the course of a day.
So would check the regulator first before pulling the furnace.
I believe the service tech attached a manometer (?) to a port in the range and monitored propane pressure when the furnace tried to run.
Actually, this may not be your issue as your furnace runs for 3-5 minutes? Mine would sputter for shorter periods, igniting briefly then dying.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
