BrianinMichigan
Nov 20, 2014Explorer
Overdrive, Do have a ohm meter or have access to one. I believe there are two valves on the gas valve. Pull the wires on both of the valves and measure the resistance of the coils on the valve. i believe they should be around 90 ohms. When mine stopped working one of the coils opened up but the valve sounded like it was working because of the other valve clicking. I found the wire on the coil had oxidized so bad it fell off of the coil. I unwrapped it a couple of turns and soldered it back on. It worked for a year or so and I had to do it again. That when I bought a coil of magnet wire and re-wrapped the coil. It's been about 6 years and it's still going strong.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
